AutoCAD LT Forum
Dim text - Feet/ Inches to Inches only
5 REPLIES 5
toddrgilbert
837 Views, 5 Replies
I am trying to change the way the Dimension Text reads from Feet and Inches (ex. 6'-5") to read only in Inches (ex: 77").
I need to do this in order to help eliminate field errors in reading the incorrect number of feet.
Any help on this topic would be greatly appreciated.
Todd Gilbert
McKimmey Electric
5 REPLIES 5
in reply to: toddrgilbert
Change UNITS and/or Dimension Units to decimal, add the
symbol " for DIMPOST variable.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
toddrgilbert
Thank you for your help.
You may want to investigate fractional units too. That way 5'-7 5/8" come
out as 67 5/8" instead of 67.63.
Brad
wrote in message news:5527883@discussion.autodesk.com...
AMTaylor
Can you explain what menu/command I need to go to do this?
UNITS and DIMSTYLE commands, just type them at the command
line. Tap the Help buttons on the pop-ups for explanations.
Dean Saadallah
”Boost
