Using '09LT and was wondering if it's possible to have different line type scales in different viewports on the same layout tab?
Thanks.
No, not the way you describe it: but you might benefit from setting PSLTSCALE and MSLTSCALE differently from what you have now so that you get that effect in scaled viewports that don't match each other. remember, LTSCALE variable will affect the settings of the two variables noted above, as will CANNOSCALE variable.
Post back if you get stuck and list your setings for all four variables.
I'm working on someone else's drawing. A 1/4-in viewport shows batt insul that is two big and bleeds outside the wall cavity but in my 3/4-in scaled viewport, it looks perfect and is within the wall. What's going on? The owner of this file likes to keep the box checked in LT manager so that linetypes are scaled in paperspace. The universal lt scale is 1. I checked MSLTscale and PSLTscale. All 1. I hope that someone might help.
Ok thanks. Here's a copy of the dwg. Just regen the vports if you need but you'll see the same hatch for batt insul fine in the enlarged details but not in the overall section.... Never saw this before!
