Oops, forgot what group we were in -- no LISP in LT.
"Kate M" wrote in message
news:5753497@discussion.autodesk.com...
1) To repeat a macro, you have to either pick the button again or get it out
of a right-click menu. So, set your right-click to be time-sensitive. That
way, you can quickly click for enter, and long-click for a shortcut menu. I
think you'll find it's a nice compromise.
2) No. If you put it into a LISP routine, you could have a shortcut that
started the LISP, but it doesn't work for macros.
wrote in message news:5753378@discussion.autodesk.com...
Fantastic thanks so much Brad, I done what you said and made a button on my
tool bar and it works but there was just two other things relating to the
same thing if you wouldn't mind helping me again,
1) My right click is set to ENTER and REPEAT COMMAND but when I right click
and select the same object or another object it goes straight into the
rotate part of the command without copying it first (I'm trying to do
multiples of the same command but without pressing the button again)
2) is it possible to edit the acad.pgp file and put a command in it so I can
press a key on the key board to invoke the command.
PS. Sorry if I sound a bit stupid, I have been using cad for years and just
draw, never played with commands etc.
Many thanks
