AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Copy/ Paste crashes AutoCad
31 REPLIES 31
Message 1 of 32
dipen
15840 Views, 31 Replies
Hi All.
Im using AutoCAD LT 2012 and evertime I try to insert a block or paste something from the copy with basepoint command, AutoCAD crashes.
Any idea what's causing this?
31 REPLIES 31
Message 21 of 32
dipen
in reply to: pendean
I'm not sure if this will help, but I located the problem. My consultant's consultant software. Certain areas of the drawing were copied from civil designer, that’s were the problem came in.
Not sure if this will lead to a solution?
Message 22 of 32
pendean
in reply to: dipen
Are they using Autodesk software? If yes, then they need to use -EXPORTTOAUTOCAD command (note their is a dash in the name of the command) to send you 2D only files with no custom objects.
Message 23 of 32
faniadv
in reply to: dipen
Try FILTERS command and delete all
Message 24 of 32
pendean
in reply to: faniadv
To delete all filters, just start LAYERSTATE command.
Message 25 of 32
faniadv
FILTERS command with an s and then save
Message 26 of 32
faniadv
It did not work for me with that command, but it worked with FILTERS
Message 27 of 32
philtee
Try selecting the checkbox "explode" on the insert dialog box then OK
Message 28 of 32
ScottHodges
in reply to: mierzvoj
Have you tried using the cut and paste commands from the menu, rather than the Ctrl+C & Ctrl+V ? Sometimes applications can remap the windows chortcut commands
Message 29 of 32
timsparks6941
in reply to: ScottHodges
I've found that bringing a drawing into Microstation V8i will fix an AutoCad drawing.
Message 30 of 32
plleras2211
Hi there
Go to the block...open it and make a purge. Verify your layers. Maybe it has to many layers that need to be removed. Drawings on recent versions can be saved for older versions....there's a setting on options for that.
Try inserting the drawing block as an external reference just to see what happens.
You can try making a WBLOCK on it.
Message 31 of 32
oktayhasanzadeh
in reply to: dipen
I had the same problem. I deleted all the layout tabs and it worked.
Message 32 of 32
havlatm1
in reply to: timsparks6941
I had the same problem. I tried amost all possibilities metioned here. Only DGNEXPORT and than DGNIMPORT works. Thanks!
”Boost
