AutoCAD LT Forum
Convert Autocad.dwg from Inches to Millimeters
5 REPLIES 5
3368 Views, 5 Replies
How do i convert an existing autocadlt drawing from inches(units) to millimeters (units)
5 REPLIES 5
it's ok the cloud in my brain has finally moved on.
All I had to do was type in units and then I could change to what ever I wanted
Well...not really. Your drawing may need to be scaled up by a factor of
25.4.
___
"Joe3575" wrote in message
news:f0de4f5.0@WebX.maYIadrTaRb...
wanted
In your dimisions dialog box their is a tab called alternate units click display alternate units then put in 25.4 in your multiplyier for alternate units percision to whatever you want and decimal is standard to go at least 4 places!
also if you starded in inches you may have to scale dwg by 25.4 to get correct just like paul said!
Changing the units is not a correct way although it is more convenient. It only changes the units you view.
You may experience problem if you export the drawings into other formats, such as: dxf.
Besides of scaling the whole drawing, you may also copy all the entities into a new drawing which use metric system as template.
However, you may need to manual copy some of the unused blocks and layers to the new drawings.
Good luck.
”Boost
