Currently in AutoCAD LT 2013, was in 2000. In 2000 I had a drop down menu where I could change the background color. I used it to change the background to white before printing. In this forum I found out how to select monochrome in the print menu and haven't needed to change the background... till now. When I print to my copier or to PDF the background is white like I wish. Then when I copy from PDF and paste to Word, the image is hazy. If I copy and paste to Paint, the background is black. The most important thing I wish to figure out is how it may be possible to transfer an image from my drawing to the manual I'm building in Word without it being hazy or black background, but I would also like to find how to change the backround color. All ideas, suggestions, comments any wish to offer will be greatly appreciated. Thanks, K.
Solved by kthr331. Go to Solution.
Thank You pendean for considering and responding to my post. That suggestion to PLOT to a raster image file format is fantastic, wish I had been led to that years ago. Appreciate the help. K.
