Show only
Search instead for
I need to open a BAK file. Acad reports an error because the extension isn't
dwg. I seemed to have lost the method for doing this. Can anyone help.
Ian
AutoCAD opens .DWG files. Rename your .BAK file by changing the extension
from .BAK to .DWG. Be sure that Windows is set up to display all file
extensions (Folder options ...).
___
"Ian Robinson" wrote in message
news:42248f53$1_3@newsprd01...
>isn't
Are you changing the file extension?
If Windows Explorer does not allow you to see extensions, you cannot change
them. Perhaps that is your problem.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Or just change the setting in windows.....
"derekagar" wrote in message
news:12115942.1109770409044.JavaMail.jive@jiveforum1.autodesk.com...
> Can't see the extension in windows??
> Back to good old DOS......
> DA
Thanks all - panic over!
"spanna" wrote in message
news:9353247.1109936521048.JavaMail.jive@jiveforum2.autodesk.com...
> open explorer
> tools - options - view
> then untick the box that says hide file extensions for known filetypes
> you should now see the extension as filename.bak and you can rename it to
filename.dwg
