Hi
I didn't realise they were discussing ADT, but it explains exactly what is happening to me. - Automatic Dimstyles overrides all over the place.
Its an old drawing, an even after purging the file, and WBLOCK, it still happens.
The issue is when I am dimensioning, and shift between views, the DIMSTYLE automatic creates/returns to an override style. I can then use match properties to get it back to the main style, but this is boring.
Now I've also got a situation where I need to dimension inside layout space, and I set the DIMLINEAR SCALE to reflect the viewport I am dimensioning off (1:50). The first dimension is fine, but subsequent dimensions (even when using the continue command) automatically go to an override style and increase the DIMLINEAR SCALE by a factor of 500 ?
LT2009 - and yes, its more than one drawings and they are from a template I made, but how do I stop this from happening at the template??
