AutoCAD LT Forum
Autocad vs autocad lt for a tablet
3 REPLIES 3
614 Views, 3 Replies
Im going to be running one of these on a tablet to do minimal drafting and was curious if one is easier on the machine then the other. If i have the full version of autocad and am only using it to draft small 2d projects will it run the same as if i had autocad lt doing the same drafts?
3 REPLIES 3
DarrenP
neither are optimized for a tablet yet
you still need a mouse and keyboard to make use of both programs for the most part
no Autocad will probably use more resources not much than autocad LT
DarrenP
Ok thanks, i have a 2 in 1 tablet with windows 8.1 and it runs Autocad `student version` fine for what im doing but i did notice when a draft gets larger it tends to run a little slower. Was mainly checking if Autocad LT would run it any better then the full version or if the difference is so minimal that the LT purchase would be a waiste for now.
pendean
It's the same core program for both variants, so you will see little speed gain between the two.
Tablets are just not designed for the horsepower AutoCAD/LT require so expect slowness.
”Boost
