Hi, I'm doing a very simple drawing in 2D on LT2013, I have 3 layers and therefore 3 colours of lines on the screen, red white and grey colour 8. In previous versions of LT the line colour will appear as one flat colour for every single line on that layer, regardless of whether the line is vertical or at 45 degrees or horizontal. In LT2013 it seems that only horizontal lines are displaying in this way as the correct layer colour, but vertical and 45 degree lines (incl. hatch eg ANSI32) are lighter, to the point they are white. This means I can't differentiate between lines that are on Layer 0 white and lines that are on Layer Hatch Colour 8. Is there a way to render all lines their true colour on the screen so I know what layer things are on without having to click on them? Any help would be much appreciated 🙂
Solved by simon. Go to Solution.
Solved by pendean. Go to Solution.
Solved by Charles_Shade. Go to Solution.
That is a monitor and graphics card issue.
Or could be an AutoCAD Modelspace background color issue.
SWAG - Maybe try turning off Hardware Acceleration?
Change your colors perhaps to something that you can see the difference?
Anything else different from your previous version of LT and the new LT 2013 install?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Did you change PCs with LT2013? There is no "angled lines are colored differently" setting in AutoCAD, LT2013 or lower, but LT2013 is by design set to use (and abuse) a graphics card fully with hardware acceleration unless you turn that feature off using 3DCONFIG command (your older LT versions had no such abilities).
I have reset all my monitors settings to ‘restore’ and then taken it off ‘gaming’ settings and set it to 'text' setting (I didn't even know it was on these settings) it’s very dark but the lines have all gone the same colour – I think this is problem solved 🙂
Many thanks for both your help,
Kind regards,
Janine
