I recently applied the ACAD LT 2014 update and now I get the loading splash screen showing everything loading, but when it looks like it's done it closes every time. I've restarted the computer multiple times, but I cannot get it to open.
Help!???
thanks!
Kevin
Solved by kevinweinberg. Go to Solution.
If you're using a Stand-alone license, perhaps try resetting it.
Have you tried to uninstall the update? If you suspected it's the one that cause problem, you might want to try uninstall it first.
This didn't work -- the file wasn't there (I also searched and couldn't find the file elsewhere).
Thanks for the suggestion...
You probably didn't get it installed succesfully.
Can you check in ABOUT? Type ABOUT then enter.
Do you see SP1 in product version as below? Mine says AutoCAD 2014 SP1.
So I just uninstalled the program all together and re-registered and applied the update after re-installing and that worked. It came back up with no issues. Thanks everyone for the suggestions!
