Hi at all.
On my business PC acadlt.exe crashing when i try to convert my dwg file on another format type.
For example if i would to covert my dwg in a PDF file, i go on action bottom "A bottom", i go on EXPORT and to PDF.
ALL ok but if i press on SAVE the program have a fatal crash.
My pc have Windows 7 pro 32bit, i have install the SO by 2 day, i have installed all the windows update. The user profile is OK and if i access on pc witch another profile the system have crash too.
I have java 7 u21 and .net 4.5. On similiar PC the program dont crash.
I have try to reinstal .net and Autocad, i have try to search on google but nothing as work.
Anyone have an idea?
Tanks
M
Thanks for the reply.
The problem has existed since the first installation.
When I use the plot command, the file is converted and the program crashes soon after.
The same problem occour when I export to DWF or DGN.
If on plot menu i use PDFconvert it all works.
any ideas?
You may have a bad installation. is LT2011 fully patchd and updated? Worth trying that first.
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
More complete .NET fix if you did not go through this procedure:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Download 2010 through 2014 software:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
hello
I've done everything you suggested but it does not work.
Every time I convert the files to export the program crash
nobody has an idea about what can cause this error only on this pc?
if I open the error report autocad: unhandled exception version e.49.0.0
