Hello, I need assistance with configuring plotter/printer on newly upgraded laptop using Autocad LT 2007 with Win7. The printers that are re-installed are not available under that program. Thank you in advance for your assistance.
Welcome to the Autodesk Forums!
From the Commmand line: OPTIONS, Plot and Publish Tab, uncheck Hide System Printers in the middle right of the dialog.
Do you have your printers available now?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi Charles, yes, some are available but not the plotter and the hide printer box wasn't checked. Any other suggestions. Thank you! Renae
Are the plotters shown in the Windows printers list (Control Panel\Hardware and Sound\Devices and Printers) ? If not, you will need to install the Win 7 drivers for the physical plotters you have, or if you have a HP plotter, the generic HPGL plotter driver often produces a better plot.
Have you gone thru the Printer/Plotter Wizard within AutoCAD to create a PC3 file for the Plotter in question?
