I bought a laptop with Window 7 installed. Will ACLT 2000 operate on this platform?
I can draw with it but the drawing must be gotten out of and (saved) restored appox. every 6-7 minutes
If not, all the work done is lost to a point before.
Thank you for your valued time.
Mike
If your Win 7 install does not allow previous OS emulations of older software installs you can find info for the the add-on here: Win 7 Emulation.
This may cost you a few bucks and not solve the problem. Win7 Enterprise and Ultimate come with this built in.
Not knowing what platform LT 2000 supports you may be tweaking to get a stable install.
There may be others here who have made a similar setup work. Or you may want to try:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
will it operate maybe, maybe not
this came out over a decade ago
so chances are slim that it will work without problems on a newer OS
DarrenP
