AutoCAD LT General Discussion
Active Member
wasicekr
Message 1 of 14 (4,709 Views)
AutoCad 2012 LT copy and paste not working
4709 Views, 13 Replies
08-10-2012 10:15 AM
I have recently upgraded to AutoCAD LT 2012. The copy/paste function and the group/ungroup function are not working. I have run service pack 2 with no improvement.
What is the fix for this?
pendean
Message 2 of 14 (4,705 Views)
Re: AutoCad 2012 LT copy and paste not working
08-10-2012 11:18 AM in reply to: wasicekr
For GROUP to work, you must have PICKSTYLE set to 3 ideally (1 at a minimum): do you? Same with older and newer versions of LT.
As for copy/paste, is the problem ALL files even if you start a new one and draw a few lines to test on? Or just the one file or few files you've tried so far? What method of copy/paste are you using exactly? name the commands or butons you pick.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
wasicekr
Message 3 of 14 (4,700 Views)
08-10-2012 11:21 AM in reply to: pendean
I have used Ctrl C/Ctrl V, the copy and paste buttons in toolbar and right click copy and paste to clip board.
pendean
Message 4 of 14 (4,698 Views)
08-10-2012 11:23 AM in reply to: wasicekr
"...., is the problem ALL files even if you start a new one and draw a few lines to test on? Or just the one file or few files you've tried so far?..." Works fine here so it would be good to know what else is different.
Windows version?
Active Member
wasicekr
Message 5 of 14 (4,694 Views)
08-10-2012 11:32 AM in reply to: wasicekr
Windows 7.
The copy paste will work on a new drawing but not any existing from drawing to drawing.
pendean
Message 6 of 14 (4,688 Views)
08-10-2012 01:04 PM in reply to: wasicekr
Try this test: in the existing drawing where it will not work, draw a line, then try to copy/paste it inside the same drawing. If this works, try copy/paste this same line to the other drawing where it failed.
Let us know who it all worked.
Active Member
BadandMadMartin
Message 7 of 14 (4,651 Views)
08-13-2012 01:14 AM in reply to: wasicekr
Hi wasicekr,
When copying and pasting between drawings, when copying, you need to hold down Ctrl, Shift and c rather than just Ctrl and c.
This caught me off guard as well.
Hope this helps,
Martin.
Charles_Shade
Message 8 of 14 (4,642 Views)
08-13-2012 05:03 AM in reply to: BadandMadMartin
Interesting. Maybe that is why the issue popped up.
One more thing to try.
When you Copy from one Drawing to a another and it does not work take a moment and from the Command Line: OPTIONS then click OK.
Is Paste available now?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
pendean
Message 9 of 14 (4,637 Views)
08-13-2012 05:25 AM in reply to: BadandMadMartin
CTRL+SHIFT+C is COPYBASE command, always has been.
CTRL+C is COPYCLIP command like in all other Windows: there is no variation in LT2012 here so I'm not sure why you all think it has changed.
There has been no change, not even in LT2013.
Active Member
BadandMadMartin
Message 10 of 14 (4,632 Views)
08-13-2012 05:54 AM in reply to: pendean
I only had to start using Ctrl, Shift and c for copying and pasting between drawings since 2011, versions before that I could just use Ctrl and c and it would do it without any problems.
You are not logged in.
Ask the Community
