When I click any menu button inside the "online" toolbar tab for AutoCAD WS nothing happens. For example- If I click on "Online Drawings" nothing happens. In AutoCAD LT 2012 that button would take me to the AutoCAD WS site. None of the links in my "online" group work in LT 2013.
How do I enable these links withouht having to mess with uploading files to Autodesk 360?
Solved by pendean. Go to Solution.
Did you by chance "migrate" when you installed 2013? Your description of 2013 buttons seems better related to 2012.
Start HELP in 2013, in the search box type AUTOCADWS, instructions about use seem to work here:
"To Open and Edit Drawings using AutoCAD WS
Click Online tabShare and Collaborate panelCollaborate Now.At the Command prompt, enter ONLINECOLNOW.
The current drawing is uploaded and opened in AutoCAD WS. Use the available online tools to edit the drawing and collaborate with others. "
Don't fear '360': it's new and 2013 is all about it (LT2012 is not aware of it). Remember to install the patch recently released for the 360 module.
I would ditch that migration: remove and reinstall LT2013 and get back the new features/setup. Ensure you selected to install 360 (on the disc, requires an active selection) unless you know it's running in Windows in the background (it starts when 2013 starts).
