AutoCAD LT Forum
AutoCAD Lite 2013 (slow publish)
5 REPLIES 5
806 Views, 5 Replies
I am having a little problem with AutoCAD Lite 2013 and is that when I have 7-10 sheets to publish it is taking a lot longer than other systems. Moreover, the other systems have the exact same performance specifications.
Thank you for your help!
5 REPLIES 5
Charles_Shade
Network printer or just Publish to PDF (or File)?
in reply to: Charles_Shade
Publish to PDF (10-12 sheets takes 10-12 minutes).
Charles_Shade
New occurence or previously ongoing?
If new a System Restore to prior to the problem may help.
What is different about the other machines? And not just specs, programs and add ons.
This is a brand new system and this will be the first time this happens.
pendean
Do you have background publishing on? Turnit off in OPTIONS command's Plotting tab. It's turned on by default if you just start using a new setup.
”Boost
