Does anyone has alredy had a problem when selectiong objects in LT the cursor gets stucked and very slow?
Thanks !
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
Solved by clacampos. Go to Solution.
Hello
Q1) Please which ACAD LT exactly ? with which SP ??
Q2) 32 or 64 bits ?
Q3) On which Windows exactly ? (Win XP Pro , Win Seven , Win 8.0 , Win 8.1) ?
Patrice BRAUD
Hi Pat,
Thank you for answering!
It´s LT 2014 updated, 64 bits, windows 7 Professional.
But I find the problem, it was because the graphisc card was not recommended or tested and I turned off hardware acceleration and it solved the problem!
thanks again
Claudia Campos
Hi Dean,
Thanks for your help, I just posted that I found the problem, it was the graphics card.
regards,
Claudia Campos
