I purchased AutoCAD LT 2011 online and I am trying to figure out if I have the 64 bit version. My product version is E.52.0.0.
I am looking to purchase a computer and I want to make sure I purchase the correct operation system.
Thank you in advance.
Solved by pendean. Go to Solution.
I wornly loaded 64 bit 2011 for XP home and after expanding says cannot install, but cannot find a default folder or in add/remove pgms! Online seller sent me to Autodesk who sends me back to seller on how to remove and download 32 bit. Any suggestions?
Follow this advice from Autodesk for Registry Entries. Should get you back to a clean install.
Remove Autodesk Products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Then Dean's link above and request the media. I've read too many problems with downloading the program. Good to have something solid in your hands.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
There is nothing to remove/uninstall if it did not install, as it apparently did not.
If you just want to delete the folder that it expanded to, use Windows Explorer: you did keep track of where that ended up, correct? normally it's at c:/autodesk/PROGRAMNAME
Thanks.
Now as I see no way oto mark this as instructied per help - "solution?" Maybe when I post?
@pendean wrote:There is nothing to remove/uninstall if it did not install, as it apparently did not.
Since you did not originate the thread you cannot Accept as Solution
Thank you, sir!
I spent servealminutes tyring to find the icon and after posting reply to what turned out to be the proecess that got me cleaned up and installed trying to understand what I missed. Guess, I need to read the entire help information.
Unhappy camper at present - I called the online seller per Autodesk website for help who set me up an account so I could use something called "Up & Ready" as he said they had no idea. Up & Ready wanted me to subscribe before would provide nay help, but somehow gave me option to e-mail Registrationa and Activation. They e-mail that they only to Reg & Activate issues! Seems like my problem to me?! And they continue that my problem is issue for the online sales dept.
Good thing Autodesk has a good prodect and widely used, their help and service departments would put them out of business in 3 days otherwise.
But, I am up and going and starting with the "rebbon". Expected retirement to be simpler than this. Again, thank you.
