My office recently received the update from 2013LT to 2014 LT, and after installing them, I'm noticing an issue that I don't understand.
If you go to the link below, you'll see a video of the problem. Basically, when more than one drawing is open, as the user pans around or zooms in and out, the application status bar starts to go nuts, with the word "unrecognized" popping in and out, as well as a small symbol to its left. Also, while all of this is happening, the colour in the layers bar at the top of the drawing flickers somewhat randomly. So far, 5 of the 11 copies have had this issue, and 3 of those licenses haven't been used yet.
I'm experiencing this on multiple machines, across multiple platforms. This includes Core I7's with 8 Gigs of DDR3 RAM and Radeon 6450's running windows 7, all the way to Core 2 Duo's running 64 bit XP with 4 gigs of DDR2 RAM.
Please see video below:
Any help is greatly appreciated!
Solved by yooperjeff. Go to Solution.
Nice! Dragging in the AecCore from 2013 and renaming the one found in the 2014 Lt folder to AecCore.crx.old seems to have worked quite nicely. I'll have to see if this works on other PCs, but at least we're finally getting somewhere.
Thanks!
This is looking good. I will guinea pig someone in the office to see if this fixes the flickering! If it does we might have a solution! Oh yeah! 😄
I can confirm that the CRX rename fix works. We also copied the LT 2013 CRX into the 2014 folder. All seems to be fine! No flickering here!
I also this irritating laggy flickering when more than one file is open. LT 2014 on Win8 64.
What's a good way to get the 2013 AecCore file?
GChapp
Nice one you guys this has been frustrating me all morning. Thanks for the fix. Works a treat.
Here is the AecCore.crx from AutoCAD LT 2013. use this to replace the same file in 2014
I checked my flickering issue on both my Dell laptop and my home built desktop. Both had it when two drawings were open. It would flicker on pan & zoom.
Also, both had the problem with slow saves with a temporary black screen.
So I replaced the AecCore.crx file in both computers.
Now neither computer has the flickering problem, and neither computer has the black screen lag on saving so far.
Both are much more usable for actually getting work done.
Thanks for the file and the help.
GChapp
Seems like a good place to drop a general reminder to those who have implemented this fix: document the changes you have made to your computer. Note what was renamed, what was deleted, what was replaced (and have a copy of the replacement file as well). SPs, hotfixes, and other subsequent changes may not account for any changes made in this fashion so it may be of benefit to change things back to the original conditions prior to applying any future updates.
Don't count on being able to remember "I renamed that file, and the other file was replaced by one I downloaded from... uhm... where was that again?"
This certainly seems to have worked for me.
Running LT2014
Windows 7 Pro 64bit
4gb RAM
NVIDIA GeForce GT 620
Cheers.....Q
More on this AecCore.crx issue.
I found that when I did a WBLOCK on a whole drawing, that the text window showed an error that it could not load the AecCore.crx file. Gave me a black screen for about a second.
But . . . The WBLOCK worked fine. I have no idea what this AecCore is supposed to do.
GChapp
Welcome to the Autodesk Forums PaulBoyce2132!
Many do not use the new release until the Service Pack comes out just so these issues get resolved and do not cause a problem. I suspect this issue will be part of the SP.
Sometimes getting the software out to the users is the only way these things pop up.
Finding what happens when item C is changed and effects item D7Axp9 on line 4,532,618 in the code when used on machine A-Z from 500,000 random users can cause a glitch.
It's easier to win the lottery I should think.
Maybe no excuse but there is a lot of interaction that goes on that when the minions start toiling in the background.
Oh yea, and we can reprogram the software to suit our needs as well to a certain extent. Would that double the permutations?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
@Charles_Shade Whilst I agree with your sentiment that it is hard to find these bugs in testing and only when publicly issuing the software do these things pop-up it is hard to feel "sorry" for AutoDesk in these circumstances.
It is now nearly 2 months since this issue has been raised. Several of us have raised it with our CAD support companies so AutoDesk will definitely be aware of this issue. As it makes the software pretty much unusable a hotfix should have been issued by now. Even it is just an automatic version of the file replacement noted on this forum! People do not like paying thousands for broken software!
I do agree Paul that AutoDesk should be working on stability over new features. Especially now that they have pretty much gone over to a subscription based system.
Also why doesn't AutoDesk have an auto-update feature for their software? Adobe does? So does Firefox and Chrome! Hot-fixes will be much easier to roll out with a rolling update system like these! I find AutoDesk to be way behind the rest of the software world in this respect.
(Awesome the spellcheck does not know AutoDesk! )
If you are signed into Autodesk 360 and Info Center you will be made aware of any updates to Autodesk software each time you start the Program.
Some offices (like ours) don't use 360 as it has been known to break things. Also many of our users do not have 360 accounts and do not wish to do so.
My point is that the update should be automatic, that way small updates can be applied easily. The mechanism of Service Packs is redundant and incremental updates is the way the rest of the world operates. This also means any problems a patch can be written and rolled out to users without them waiting months for the service pack to arrive.
A pop-up message that a service pack is ready is pretty much a token gesture.
I tend to have many problems when Microsoft decides to automatically update my machine therefore I do not allow MS to do so.
Adobe asks about every other month if I want to update Flash and the reader from time to time.
I don't use Apple's media player but do remember it wanting me to update from time to time.
The Fences software keeps wanting to update that software as well.
CCLeaner will ask me to update if I have that feature on as well as SpyBot.
It is my choice to update or not and in some cases select whether or not I am notified of updates.
The choice is yours on some of these on others you have to answer a question.
I for one prefer being in charge.
We get exactly this same thing.
We have decided to uninstall 2014 across all 5 machines as it is effectively un-usable.
Reading through the thread, AutoCAD are aware of the problem but refuse to resolve it. I see many suggested solutions but the final one involved downloading a file from the forum, and running it on my machine. Yeah, like i am going to do that.
How can we force a resolution of this issue?
Neil
