autocad LT 2014 keeps flickering when i only have 3 drawings open with Xref in it.
the size of each drawing is about 2-3 MB.
My pc specs are as following:
- 8 GB ram
- I5 processor HP Pro3500
- NVIDIA Quadro k600 1GB graphic card
- operating system windows 7 professional.
i tried the following options:
- install the .reg file.
- start up under diagnostic
- Reinstal autocad
- put the drawings on hard disk instead of server.
- disabled hardware acceleration or enable
all of the above didn't have any effect.
the specs of the pc are average.. what can be the problem?
Solved by Charles_Shade. Go to Solution.
Solved by pendean. Go to Solution.
Start at the end of this thread an work back as needed, different tips worked for different folks: http://forums.autodesk.com/t5/AutoCAD-LT-General/AutoCAD-LT-2014-Flickering-Issue/td-p/3875348
Ensure LT2014 is fully patched and updated too.
This is the solution the Autodesk offered:
The aeccore fix was a peer solution and Autodesk frowned upon it.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
tried the .reg file already several times but for some reason today it worked. for now at least.
thank you guys for your help.
That file worked a treat.
We have found that when old files are used this flickering happened, but when we created new template drawings from scratch, they worked fine. We still haven't pinpointed it, but we think that there is something corrupted that creates the issues, like a block or hatch. This is why it only happens to some users and not everyone. How old are you're files that you are working with?
it are all imported drawings as Xref.
The are new but i guess made in Revit and only the top view got send to me.
I have upgraded the graphics card since then and now i dont have the problem anymore..
