While using trim command in block. autocad lt 2013 gets not respnding and file must be heavy. and after it generate fetel error & shutting down See the Attachment
Hello
1) Please open your DWG in RECOVER mode and Re-save it
Re-Test ...
2) Install the SP 1.1 for LT 2013 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20327876&linkID=9240818
Re-Test ...
Bye, Pat
Patrice BRAUD
Couple of ideas here in this KB article:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=2862058&linkID=9240817&siteID=123112
Provide system specs please.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
