Working in AutoCAD LT 2010.
Drawing format 2007 or 2010
bedit, OK if you regenall after
refedit, Ok if you regenall ofter
design Center - display order goes out the window. The inserted block is redefined but the rest of the drawing loses all its display order. sortents (127, 33, 51, etc) and displayorderctl does nothing, either before or after the block is redefined. hatches and blocks just jump to the front (display order shows as order of drawn not order as moved to) Regenall does nothing.
absolute nightmare with display order managed elevations (solid hatch, baconies, windows, multple buildings, all overlaying!!)
Really need help with this (old) problem
I've noticed this from time to time too, drawing orders do not always maintain, very annoying when using wipeouts I might add.
Sortents - 127, draworderctl - 3, texttofront - both, hpdraworder - 3
What else is there?
2 XP pro desktops and 2 win 7 x64 pro laptops
very simple to test. take a drawing with a block in it and do a save as. Place a piece of solid hatch over the top of any of the drawing (SOLID is easiest) then move it to the back in display order. Redefine the block using the original dwg for the source (note block does not even have to change!!) using the design centre AND the solid hatch jumps back to the front. Then regenall and nothing happens! Block insert is fine. Just redefine.
You forgot HATCHTOBACK.
Sorry, I can't replicate here at all: hatch stays in the back when the block(s) are redefined using ADCENTER. But I'm not using LT2010, tested it in 2012 and 2013, Win7 64bit.
