AutoCAD LT Forum
AutoCAD LT 2009 toolbars??
2 REPLIES 2
311 Views, 2 Replies
I have been given a company laptop and our external IT compnay have removed AutoCAD LT 2009 and then reinstalled it remotely, since it has been reinstalled I have no toolbars and cannot find any option to add any. If someone could help me with this I would be very grateful.
Thanks in advance
Amie
2 REPLIES 2
hwalker
Welcome to the Forums
Are you talking about the ones which have the usual icons on like open, save and all those.
If so at the command line, type MENUBAR and make sure the setting is 1
Howard Walker
Left Handed and Proud
pendean
WORKSPACE command, and select another to see if that helps.
There are also:
MENUBAR command as noted above.
RIBBON command
CUI command to edit and create a new workspace with whatever you want if you already tried my first suggestion and got nothing.
REMEMBER: LT2009 doesn't show anything if you simply start the program with no file. Is that perhaps your issue? open a DWG file or start a new one to solve the problem.
”Boost
