I am trying to import XY data into Matlab from an Autocad 10 DXF export ASCII file.
This data is from a flat drawing (no Z dimension.) When I import the
lines, polyline, and hatches, some of the data has a different coordinates
system than the others, and possibly a different scaling. Are there some
DXF attributes I should check to find the appropriate reference points and
scaling for each entity type, or does this need to be discovered in the native
Autocad 10 DWG file?”
AutoCAD 10? Do you mean 2010DXF format? If the content is correct in your DWG file as you need it, perhaps you need to export to a lower DXF format like R12DXF for example.
