My leaders that worked fine up until today have exhibited the following problem: some of them, not all, will not display the leader itself (the annotative text of the leader is displayed) when shifting to a new layout at different scale. The visability is on and the object has the scale listed and properties show that it is current. The leaders that work and those that don't appear to be identical in properties.
I have been able to add a leader to the text in the new scale but this is time consuming. I suspect I inadvertantly messed with a system variable but I can't find any that address this.
Margie
AutoCAD LT 2012 & 2014 (I tried both)
Win 7
Solved by mbroller1. Go to Solution.
Actually there is some great stuff here. The annoreset solved the crazy angles I had in various scales. A problem that has plagued me for awhile. Not sure what the annoupdate does but it did not affect the problem. I did an exporttoautocad but that didn't seem to make any difference.
When I identified the scale that the leaders were in, I changed to that scale then annoreset, it worked. Then I had to move the leader back to where I wanted them in the scale that I needed them. Time consuming and I assume recreating the problem if I don't reset again.
So I guess it is solved but not in a great way. I can't fiqure how this all went heywire because I use (reuse) these notes in so many scales, all the time without problems before.
I need to use 2012 for a regular client who has the subscription but don't have the time to deal with the upgrade process on all their stations, so they just plug along with 2012. (It took me 2 years to get them out of 2007). And I agree that 2014 is generally better but it crashes alot more than 2012.
