Que tal amigos mi motivo es por lo siguiente, tengo un problema con su producto autocad
Similar Error:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=6038619&linkID=9240817&siteID=123112
and link to KB site:
Possibly you need to make sure the install is clean:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
AND:
.NET updates to Windows can cause issues as well
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
You need to eliminate what may be issue now that you have tried to reinstall the product.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
