I've recently upgraded to Autocad LT 2013 from Autocad LT 2000. In LT 2000 I was able to use the 3D Dynamic View command to rotate the view of objects I had created. Has this command been removed in LT 2013, or has it been replaced with something else?
Solved by pendean. Go to Solution.
the VP command may help
