AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
2014 LT inserting Block - scale factor greyed out set to 1000
3 REPLIES 3
qfanatiq
2847 Views, 3 Replies
Created a block, from another, already in drawing, save block as (4bay window to three bay inwdow)
When in insert, the scale factor is set at 1000 and I cant change this. My only other way around it is to explode a 4 bay, make it a 3 bay, then use the create and retain as block.
1:1 scale in model space same in block editor. how can i change the scale factor?
Cheers.....Q
3 REPLIES 3
pendean
in reply to: qfanatiq
scale factor? Do you mean the BLOCK UNIT "factor" on the INSERT command pop-up? The pop-up that has a help button, that when clicked, explains this is covered by the INSUNITS variable with a link explaining it's usage 🙂
So what is INSUNITS set to in your file? it's a per-drawing setting, not a universal one. Start there. I like a setting of 0 (zero) myself, but that may not work for you.
qfanatiq
in reply to: pendean
And people say you cannot detect sarcasm on such forum based sites!
Dean, perfecto (Spanish for perfect) worked a treat and as you well know, you are right in every vein.
I do love sarcasm and even more so when it forms an answer.
I will try and be a bit more due diligent in looking for Help myself next time.
Cheers.
pendean
That's why I put a smiley face 🙂
We all miss simple fixes, I do too. Don't worry too much about it.
”Boost
