Created a block, from another, already in drawing, save block as (4bay window to three bay inwdow)
When in insert, the scale factor is set at 1000 and I cant change this. My only other way around it is to explode a 4 bay, make it a 3 bay, then use the create and retain as block.
1:1 scale in model space same in block editor. how can i change the scale factor?
Cheers.....Q
Solved by pendean. Go to Solution.
scale factor? Do you mean the BLOCK UNIT "factor" on the INSERT command pop-up? The pop-up that has a help button, that when clicked, explains this is covered by the INSUNITS variable with a link explaining it's usage 🙂
So what is INSUNITS set to in your file? it's a per-drawing setting, not a universal one. Start there. I like a setting of 0 (zero) myself, but that may not work for you.
