AutoCAD Isometrics WS
Board Manager
Message 1 of 22 (932 Views)
Please try AutoCAD Isometrics WS and provide feedback
932 Views, 21 Replies
10-31-2011 04:48 PM
You can try the technology preview for yourself. Learn more about it at:
http://labs.autodesk.com/utilities/isometrics/
Scott Sheppard
Program Manager
Autodesk Labs
New Member
sinbincop
Message 2 of 22 (924 Views)
Re: Please try AutoCAD Isometrics WS and provide feedback
11-01-2011 09:02 AM in reply to: scott.sheppard
When I go to the Get Started button and log in with my user name it hangs up endlessly and I cannot access the program
Member
erolland2012
Message 3 of 22 (881 Views)
11-09-2011 12:47 PM in reply to: scott.sheppard
Scott,
I really like the idea of this tool, I was waiting for an Autodesk version of I-Run since AIP 9.
Now please go further and include personal title block, configuration of Bill of Material, the possibility to hide welds on final, to be able to have Elbows in Arc, the different way to have dimensions, to remuse a configuation tool will be wonderfull.
Thank you to start this project.
I am availbale to help you to help with Inventor PCF files
Board Manager
Message 4 of 22 (877 Views)
11-10-2011 06:42 AM in reply to: erolland2012
Thank you for your suggestions. We can consider them as we move the technology forward.
Scott Sheppard
Program Manager
Autodesk Labs
dgorsman
Message 5 of 22 (857 Views)
11-15-2011 12:30 PM in reply to: scott.sheppard
Not a bad idea.  Individual customization is essential, as we (like others) don't use everything on one iso (welds, cut piece IDs, spool IDs, etc.).  A couple of things to note on a submitted test PCF:
  • incorrect flange orientations
  • bolt length formats are a bit off; even though we do metric lengths for everything bolts are commonly spec'd in imperial dia. x length
  • no weld dots?  "Implied" welds at components should be processed, too.
The processing time is a little slower than running ISOGEN natively.  Of course, with the raw PCF files its a little easier to set up batch pre/post processing before the files are sent off.  And having a common setting for for all concerned can virtually guarantee consistent isometric generation without having to fight through pre-existing CAD configurations in different offices (e.g. out-of-office stress engineers or multi-EPCM collaborations).
Some clients might be a little wary of information security, especially those using licensed processes.
Might be a little early in the project, but please take some forward thought on how to hande jacketed piping.  Its the biggest hurdle I keep coming against when configuring isometric generation.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
New Member
140574
Message 6 of 22 (811 Views)
12-01-2011 01:22 AM in reply to: scott.sheppard
Good Work. Only ...when I generate the iso, all part are separated on a drawing. I dont get a complete iso. I made a pipe run in Inventor and convert it in the ISOGEN tool.
Board Manager
Message 7 of 22 (810 Views)
12-01-2011 07:29 AM in reply to: scott.sheppard
Thanks for trying it. Can you send me the file so we can use it as a test case? We would treat your data with confidentiality.
Scott Sheppard
Program Manager
Autodesk Labs
Active Member
Message 8 of 22 (713 Views)
02-07-2012 05:33 AM in reply to: scott.sheppard
Great idea! I had enquired recently about something along these lines.
Plant 3D is tops for generating ISO’s, however, when using real 3D (Inventor), the pcf is sadly lacking in data and it is not compatible with Plant 3D. Do you have plans for an “ISOGEN” type tool that allows one to modify the pcf e.g. add supports, bolts, half-couplings / threadolets, floor/wall entry etc. and to enhance the pcf to make it compatible with Plant 3D format?
Thanks for the effort!
dgorsman
Message 9 of 22 (699 Views)
02-08-2012 11:23 AM in reply to: oldgrey1
"Read" 3D?  :smileyvery-happy:
Please, please PLEASE consider something other than PCF.  Preferably XML with an open-source schema.  Currently there is no public documentation of the full PCF standard or the interface and trying to insert "things" into the plain-text format is buggeringly difficult.  PCF may be the only format in common use but lets try to get some competition going...
Board Manager
Message 10 of 22 (696 Views)
02-09-2012 08:26 AM in reply to: dgorsman
As a means of obtaining asbestos chaps, what format do you suggest? Most formats have geometric primitives defined in them already.
Scott Sheppard
Program Manager
Autodesk Labs
You are not logged in.
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Ask the Community
