• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Freestyle
    New Member
    penderw
    update invalidates serial #/product key
    1665 Views, 6 Replies
    09-19-2010 11:54 AM
    I allowed Freestyle to install an update, and now have to re-enter my serial # and product key. I cannot find either, can you help?
    Warren Pendergast
    Please use plain text.
    Board Manager
    Re: update invalidates serial #/product key
    09-21-2010 01:14 PM in reply to: penderw
    hi -
    This should not have happened.  Can you post a bit of information about your system - what browser you are using, etc so that we can debug this for future releases?
    In the meantime, here is where you can look up your serial number - https://store.autodesk.com/DRHM/store?Action=DisplayDownloadInformationPage&SiteID=adsk&Locale=en_US...
    Hope that this helps.
    Lisa
    Lisa Crounse
    Product Manager - AutoCAD
    New Member
    mike_french
    09-30-2010 12:42 PM in reply to: penderw
    For what it's worth, I received the same error during my first out-of-box installation yesterday.  But I simply canceled out of the installer/updater then relaunched Freestyle from the start menu.  It launched without difficulty.  Subsequent deinstalls/reinstalls (to confirm the lack of user selectable installation directories) have not replicated the error.
    So I hope you have... tried to launch Freestyle like everything was normal.  If it works, it might give you time to find your key information.
    Mike
    New Member
    wbhalper
    10-04-2010 06:59 AM in reply to: crounsl
    Same thing just happened to me.  Downloaded and installed the update, now there's a dialogue box asking me to enter my serial number.
    System is nothing special.  I'm runnng Vista, 3Gb Ram, 500Gb HD (that is a clone of a smaller disk that was the original install disk for Freestyle).  The only other Autodesk product installed is SketchBook Pro 2010 R1.
    Employee mwn
    Employee
    10-06-2010 10:58 AM in reply to: penderw
    Freestyle's standard installation path is C:\Program Files\Autodesk\AutoCAD Freestyle.  Is your install path different from this?  For example is Freestyle installed on a D: drive or some other situation that is different from the standard?
    Michael Nauman
    AutoCAD Freestyle Test Devleopment Lead
    Employee mwn
    Employee
    10-19-2010 09:52 AM in reply to: mwn
    For those of you who have been prompted to input your serial number and product key during the Update install could you please answer a few questions for me.
    1. What Operating System are you using?
    2. Are you logged in as an administrator when you install the Update ?
    3. What is the path that Freestyle is installed to?  The default is C:\program files\Autodesk\AutoCAD Freestyle
    4. Have any changes been made to your hard drive between the original install and the Update?
    Any additional information you could provide to assist us with debugging would be greatly appreciated.
    Michael Nauman
    AutoCAD Freestyle Test Development Lead
    New Member
    gruvsyco
    11-11-2010 09:17 PM in reply to: mwn
    Same problem here.  Windows 7 x64.  Freestyle installed to Program Files (x86).
    Tried the link above supplied by lisa and it can't find me. :smileysad:
