• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Freestyle
    nmcook1
    dwgs that start in Autocad, go to Freestyle, then back to Autocad
    1299 Views, 4 Replies
    01-31-2011 01:04 PM
    dwgs that start in Autocad, go to Freestyle, then back to Autocad.... I know the original Autocad layers are locked in Freestyle but are the original Autocad layers still locked when someone reopens it in Autocad after being in Freestyle?
    Please use plain text.
    Product Support
    Re: dwgs that start in Autocad, go to Freestyle, then back to Autocad
    02-03-2011 08:13 AM in reply to: nmcook1
    Here is the pdf document regarding the working with DWG™ files from other products in AutoCAD® Freestyle.
    To learn more about working with DWG files from other applications in AutoCAD Freestyle, you can read an article online at http://www.autodesk.com/autocadfreestyle-essentials particularly at the article about
    Exchange DWG Files with Other DWG-Based Products
    Avto Chachava
    Autodesk Product Support
    Autodesk, Inc.
    nmcook1
    02-03-2011 08:21 AM in reply to: nmcook1
    Thanks, but I read all of that and it doesn't answer my question.  I need to know if the original layers drawn in Autocad, then locked in Freestyle are forever locked if they are once again opened in Autocad?
    Product Support
    02-03-2011 09:35 AM in reply to: nmcook1
    AutoCAD layers are locked in Freestyle, but when you take your drawing back in AutoCAD you can work on original layers.
    Avto Chachava
    Autodesk, Inc.
    nmcook1
    02-03-2011 09:40 AM in reply to: avto
    Thank you!  That is what I needed to know.
