• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Freestyle
    Member
    mjcorv
    Unable to run AutoCAD Freestyle
    2076 Views, 12 Replies
    09-03-2010 08:27 AM
    The following info is displayed in a dialog box upon attempting to start Freestyle:
    Unable to run AutoCAD Freestyle.  This may be due to one of the following reasons:
    1) This version of AutoCAD Freestyle was not installed properly.  In this case, you may wish ot reinstall AutoCAD Freestyle.
    2) You do not have sufficient rights to run AutoCAD Freestyle.
    Background:
    1. Installed Freestyle on desktop PC & laptop.
    2. Freestyle app runs on desktop.
    3. Had to install new HD on laptop. This led to reinstalling Freestyle on the laptop.
    4. Upon reinstall received the message above.
    5. Reinstalled again & continued to receive message above.
    6. Assumed this was a licensing issue & contacted Registration & Activation (800.551.1490)
    7. Registration & Activation required a "Request Code" from the Freestyle app on the laptop.  Explained this was not do-able since I cannot run the app on the laptop
    8. Contacted Technical Support (425.402.8428). They had no knowledge that this software app existed & recommended I "run as" Admin.  Although I was logged in as Admin already I followed their instructions, however, once again received the above message.
    9. Spoke with Registration & Activation again and they directed me to Installation Support Group (949.595.2189).  When I attempt to call I constantly receive a busy signal.
    Any thoughts...
    Mike
    Please use plain text.
    Product Support
    Re: Unable to run AutoCAD Freestyle
    09-03-2010 08:54 AM in reply to: mjcorv
    Hi Mike,
    Sorry to hear that you are having trouble running Freestyle.
    I'm wondering if before replacing HD on your laptop, were you able to use Freestyle on the laptop?
    What OS are you running on your laptop?
    Could you provide Freestyle install log files from your TEMP folder?
    To obtain Freestyle installation log files.
    1. Uninstall Freestyle
    2. See if AutoCAD Freestyle folder is in
        Windows XP:
           C:\Documents and Settings\ your_user_name\Application Data\Autodesk
         Windows Vista or 7:
            C:\Users\your_user_name\AppData\Roaming\Autodesk
         And if presents then rename it (e.g. old _AutoCAD Freestyle)
    3. Type %TEMP% in the address bar of Windows explorer and hit Enter key to open TEMP folder.
    4. Delete the content of TEMP folder
    5. Start installing Freestyle and monitor TEMP folder for log files.
    6. Please provide log files created by the installer.
    Avto
    Avto Chachava
    Autodesk Product Support
    Member
    mjcorv
    09-03-2010 10:19 AM in reply to: avto
    Avto,
    Thank you for your quick response.  The OS on the laptop is XP Pro 2002 SP3.  Uninstalled Freestyle.  Re-Installed & received same message.  Log file is attached.
    Mike
    Product Support
    09-03-2010 11:12 AM in reply to: mjcorv
    Hi Mike,
    Based on the log file it appears that Freestyle was successfully installed.
    Can you please try starting Freestyle with /nohardware switch?
    Please refer to the post below how to set the switch.
    http://forums.autodesk.com/t5/AutoCAD-Freestyle/Freestyle-crashes-at-start-up/td-p/2692096
    Avto
    Avto Chachava
    Member
    mjcorv
    09-03-2010 12:04 PM in reply to: avto
    Avto,
    Tried the switch ( /nohardware ).  App failed again with same message.
    Mike
    Product Support
    09-03-2010 01:01 PM in reply to: mjcorv
    Can you provide your system information.  To obtain sys info on Windows XP:
    1.Click Start > Run, type: winmsd and click OK
    2.Highlight the ‘System Summary’ and then click on File and Export...
    3.Then you can save as a .txt file
    Avto Chachava
    Member
    mjcorv
    09-03-2010 03:58 PM in reply to: avto
    Avto,
    System Summary info attached.
    Mike
    Product Support
    09-03-2010 07:46 PM in reply to: mjcorv
    I’m sorry Mike, but your laptop doesn’t meet minim system requirements for Freestyle.
    •Microsoft® Windows® 7, Microsoft® Windows Vista® (SP 2 or higher), or Microsoft® Windows® XP (SP3) or higher
    •32-bit or 64-bit system
    •1 GB RAM
    •1 GB free hard drive space
    Avto Chachava
    Member
    mjcorv
    09-06-2010 01:45 PM in reply to: avto
    Avto,
    So are we just talking about RAM?  Everything else appears up to spec.  If it is the RAM can an increase in the Paging File work or must I simply purchase more RAM?
    Thanks for all your help,
    Mike
    Product Support
    09-07-2010 09:57 AM in reply to: mjcorv
    Hi Mike,
    Definitely you need to increase your RAM to 1 G at least, and please also note that your graphics card ATI Mobility Radeon 9100 is not listed in AutoCAD Graphics Hardware List, thus Freestyle has not been tested on it.  So your video card maybe an issue too.
    http://usa.autodesk.com/adsk/servlet/hc?siteID=123112&id=6711853&linkID=9240618&is_results=1&card_se...
    Avto
    Avto Chachava
