AutoCAD Freestyle (Read Only)
Mirroring Text
2 REPLIES 2
drewhinkle
3036 Views, 2 Replies
Mirroring Text
I am trying to mirror text.  Specifically, turning an "S" into a backwards S.  When selecting the character, 8 nodes appear at the 4 corners:  4 inner and 4 outer nodes to be exact.  If you click & hold one of the outer/square nodes, you can drag it horizontally, creating a mirror image of the character.  However, once you release the node the character returns to normal.  How do you get around this and create a mirror image?  It is obvious that the function resides within the software code, but I am unable to find the command to do so.
2 REPLIES 2
avto
in reply to: drewhinkle
To mirror text:
1.select your text
2.right click on it and select ‘Create Symbol from Selection’
3.right click again and select Flip > Flip Horizontal
4.once you mirrored your text, delete the symbol you created in step 2 form Symbol Libraries > Custom Symbols
Hope this helps.
Avto Chachava
Autodesk Product Support
drewhinkle
in reply to: avto
Thanks for the easy, prompt, and thorough response!
