• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Freestyle
    New Member
    drewhinkle
    Mirroring Text
    1032 Views, 2 Replies
    01-24-2011 11:32 AM
    I am trying to mirror text.  Specifically, turning an "S" into a backwards S.  When selecting the character, 8 nodes appear at the 4 corners:  4 inner and 4 outer nodes to be exact.  If you click & hold one of the outer/square nodes, you can drag it horizontally, creating a mirror image of the character.  However, once you release the node the character returns to normal.  How do you get around this and create a mirror image?  It is obvious that the function resides within the software code, but I am unable to find the command to do so.
    Please use plain text.
    Product Support
    Re: Mirroring Text
    01-24-2011 12:40 PM in reply to: drewhinkle
    To mirror text:
    1.select your text
    2.right click on it and select ‘Create Symbol from Selection’
    3.right click again and select Flip > Flip Horizontal
    4.once you mirrored your text, delete the symbol you created in step 2 form Symbol Libraries > Custom Symbols
    Hope this helps.
    Avto Chachava
    Autodesk Product Support
    New Member
    drewhinkle
    Re: Mirroring Text
    01-24-2011 01:04 PM in reply to: avto
    Thanks for the easy, prompt, and thorough response!
