AutoCAD Freestyle (Read Only)
Heidi Module load error
1 REPLY 1
1480 Views, 1 Reply
This is a new install of Freestyle on Windows 7 (HP Pavilion p6531). The program seems to work ok, but comes up with the error message on startup each time I use it. I have included a picture of the error box as an attachment (note: I enlarged the error box [in relation to the program] so that I could show the whole program  as a smaller image).
1 REPLY 1
avto
Please check your DirectX configuration, if you have DirectDraw Acceleration disabled.
Go to Start > Run > then type dxdiag in the open dialog box and click OK.
DirectX diagnostic Tool should open.
Now click on Display tab and make sure that DirectDraw Acceleration is enabled.
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
