AutoCAD Freestyle (Read Only)
Graphics hardware recommendation for Freestyle
5 REPLIES 5
avto
1543 Views, 5 Replies
Please be aware that even though AutoCAD Freestyle is an easy to use entry level program, certain minimum system and display requirements still need to be met to run and function correctly. For system requirements, see
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=15005810
Display devices must be able to support Pixel Shader 3.0 and DirectX 9.0. As a rule of thumb, graphics cards that are supported for AutoCAD will work well for AutoCAD Freestyle. A list of these supported cards can be found here:
http://usa.autodesk.com/adsk/servlet/hc?siteID=123112&id=6711853
If the hardware on your system cannot support hardware acceleration, turning it on may result in unexpected delays or errors.
While some gaming-based graphics hardware will work, they are neither optimized for optimal performance nor supported by the graphics hardware vendor for CAD use. If you encounter problems, Autodesk will not be able to obtain support from the graphics hardware vendor to fix them. Also, some of the new UI in AutoCAD Freestyle is created in the Microsoft .net platform. .Net utilizes Direct3D and video card hardware to visualize the user interface. This visualization is done even when hardware acceleration is disabled. We recommend you use a certified or tested driver for the best experience.
Avto Chachava, Autodesk Product Support
Avto Chachava
Autodesk, Inc.
5 REPLIES 5
ferreirab
in reply to: avto
I tried to change the target by adding /nohardware and still get the fatal error message
avto
in reply to: ferreirab
It will be helpful if you could provide your system information
Windows XP:
1.Click Start > Run, type: winmsd and click OK
2.Highlight the ‘System Summary’ and then click on File and Export...
3.Then you can save as a .txt file
Vista:
run msinfo32.exe on Vista.
You can also get it from Start>All Programs>Accessories>System Tools>System Information
file > save as a .txt file
Windows 7:
Thank you for contacting Autodesk Support.
I’m currently looking at your case and would like to look at your system information page.
To obtain sys info on Windows 7 please got to Start > search > msinfo32.exe
You can also get it from Start>All Programs>Accessories>System Tools>System Information.
Once system information page opens go to file > Export and save as a .txt file
You can attach the file to this post.
Avto
Avto Chachava
Autodesk, Inc.
ferreirab
in reply to: avto
Need help ASAP Already paid for software
ferreirab
in reply to: avto
Hello???
Anyone there??
Need help
crounsl
in reply to: avto
hi -
It looks like you have a very old driver on your system.  We reccommend that you go to this site- http://www.intel.com/support/detect.htm to update your driver.  Please let us know if this does not help.
Lisa
Lisa Crounse
Sr. Product Manager
