Thanks for the clarification on the double line functionality. That helps was a we consider how to approach that issue in the application.
To your other questions:
- For the property line, you can open a DWG from AutoCAD or Revit and use it as an underlay in Freestyle. In your use case, you could start by opening the DWG and then just start drawing over it. There is a lot more information about working with DWG files in the attached paper.
- You can print a PDF by going to the "Save As" menu which has an option to create a PDF.
- To send an object backward or bring forward - we have an option for this in the right-click menu. Just select the object that you want to move, and then right click and you will see something called "Draw Order" which has a sub-menu for send backward and bring forward.
- As for match properties, setting the scale regardless of paper size, and a measure area tool - these are all features that are on our customer wishlist. I will log your requests for these as that helps us prioritize features for inclusion in future releases.
We really appreciate your feedback as it helps us better understand how people are using the application. We have not had much feedback from people using the "Open DWG" functionality so please let us know what you think if you give it a try.
Lisa Crounse
Sr. Product Manager
