• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    Valued Contributor pdn
    Valued Contributor
    some expresstools commands not working
    1406 Views, 4 Replies
    07-11-2012 07:01 AM
    Hi
    I installed express tools with ACADE abd ACAD, some of them don't work, example:
    _.sysvdlg Unknown command "SYSVDLG".  Press F1 for help.
    other commands missing:
    arctextx, txt2mtxt,mocoro,dimex,dimin,qlattach
    any idea
    Thx in advance
    Patrick
    Please use plain text.
    pendean
    Re: some expresstools commands not working
    07-12-2012 12:44 PM in reply to: pdn
    Is DEMANDLOAD set to 3? required.
    At the command line, type EXPRESSTOOLS: if it fails, ET was not installed. If it works, it will load your ETs. Follow it with EXPRESSMENU command.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Valued Contributor
    07-13-2012 12:00 AM in reply to: pdn
    Hello Dean
    Tried that already, worked perfectly but nothing changed, still some commands missing
    (although always the same) seems that it won't load certain .arx files
    I can load the file manually (for example sysvdlg.arx) and then the command will work
    don't understand why "most" of the commands are loaded and some are not, have been searching where in the ACAD startup the loading appears but could not find it
    Regards
    Patrick
    New Member
    10-16-2012 12:22 PM in reply to: pdn
    I am experiencing the same problem. I followed all of the directions I could find to load Expresstools and I cant get the one command that I want to use to work (along with others). All I want to do is make my own linetypes. If someone could tell me how to either a) fix Expresstools or b) tell me how to do this without using Expresstools, I would appreciate it.
    pendean
    10-25-2012 06:14 AM in reply to: pdn
    When you installed your AutoCAD version, did you "migrate" from an older version?
    Uninstalling and reinstalling Express Tools from your program disk not an option?
