AutoCAD Forum
; error: no function definition: ACET-REG-MACHINE-PRODKEY
1 REPLY 1
wesbird
1503 Views, 1 Reply
  I don't know since when I got this error message when I start AutoCAD:
  when I try
Command: EXPRESSTOOls
Customization file unloaded successfully. Customization Group: express
Customization file loaded successfully. Customization Group: EXPRESS
  It must be part of EXPRESSTOOls. It's really annoying. I have googled it and found not solution. How I can get rid of it?
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
dmfrazier
in reply to: wesbird
It would be helpful to know what version/flavor of AutoCAD and on what platform (OS).
Assuming Windows 7, from Control Panel, Programs and Features, you could first try using Add/Remove Features to remove Express Tools.  Be sure to re-start your machine and launch AutoCAD to verify that it is removed.  Then (if you want it) run Add/Remove again to re-install it.
If this doesn't fix things, go to the next level and run a full repair and/or re-install.
”Boost
