AutoCAD Forum
Shape insertion point is offset from shape
1 REPLY 1
ben.rasenow
519 Views, 1 Reply
I am using the mkshape command to create shapes for use in complex linetypes: After I create a shape, load, issue a shape command to place it, the insertion point always ends up offset from the shape by a small amount. I wish that there was a way to designate the exact location on the shape that is will define the begining of the repeating pattern to be used in the complex linetype. This offset is introducing unwanted space into the repeating pattern, which is ruining the purpose of the shape.
1 REPLY 1
tmccar
in reply to: ben.rasenow
Can you attach the file?
”Boost
