• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    *Bartleet, Sean
    RText does not reload when drawing is opened
    51 Views, 3 Replies
    04-29-2003 03:11 AM
    I have some RText in a drawing that does not reload when the drawing is
    reopened. The RText does update as soon as I select RText from the express
    menu. Is there a way to get AutoCAD R2000i to load the object enables
    automatically when a drawing is opened with RText or Wipeout entities?
    A google search of the newsgroups sent me to a FAQ site that suggested:
    Q: Why is AutoCAD unable to find an object enabler for WIPEOUT or
    RTEXT when I open a drawing?
    A: Reinstall the express tools to update the registry so AutoCAD can find
    the appropriate ARX files to load when it encounters a WIPEOUT or RTEXT
    object. See Knowledge Base articles TS43616
    (http://support.autodesk.com/getdoc.asp?id=TS43616 ), TS64921
    (http://support.autodesk.com/getdoc.asp?id=TS64921 ) and TS59037
    (http://support.autodesk.com/getdoc.asp?id=TS59037 ) for more information.
    But none of these helped.
    The same used to happen with wipeout but I found an object enabler on the
    web (Autodesk document ID: DL101173) and that seems to work with wipeout but
    not RText.
    Any suggestions will be appreciated.
    Regards.
    Sean Bartleet
    Please use plain text.
    *Saadallah, Dean
    Re: RText does not reload when drawing is opened
    04-29-2003 09:15 PM in reply to: *Bartleet, Sean
    Another limitation to an add-on that's not a core command :smileysad:
    Dean Saadallah
    Add-on products for LT
    http://www.pendean.com
    LT Express Utilities
    http://www.pendean.com/ltexpress
    *Brown, Anne
    Re:
    04-30-2003 11:52 AM in reply to: *Bartleet, Sean
    Dean -
    Please check your email and reply to my Autodesk email.
    Anne Brown
    Manager, Moderator
    Autodesk Product Support Discussion Groups
    Discussion Q&A: http://www.autodesk.com/discussion
    *Cunningham, Aaron
    04-30-2003 11:32 PM in reply to: *Bartleet, Sean
    Add the ARX file to your StartUp Suite
    Anne Brown wrote:
    > Dean -
    > Anne Brown
    > Manager, Moderator
