AutoCAD Express Tools
Active Member
Message 1 of 28 (118,306 Views)
PDF to DWG converter
118306 Views, 27 Replies
03-31-2010 06:23 AM
I’d like to purchase a PDF to DWG converter but there are so many different applications out there – I do not know which one to choose.
Could you please recommend any?
What should I look for?
Could you please share your experience in PDF to DWG conversion?
Thank you for your help and comments in advance!
*jg
Message 2 of 28 (118,304 Views)
Re: PDF to DWG converter
03-31-2010 07:04 AM in reply to: milend
None are any good. If you use full acad 2010 you can insert a pdf or use
one as an underlay. Does that help? Don't know if LT has it. In 2008 it
didn't, but 2010 lt I don't know.
On 3/31/2010 9:23 AM, milend wrote:
> Hello,
*Terry W. Dotson
Message 3 of 28 (118,305 Views)
03-31-2010 07:11 AM in reply to: milend
> I’d like to purchase a PDF to DWG converter ...
Try the evaluation version of PDF2DWG from
http://www.dotsoft.com/pdf2dwg.htm.
Terry
Active Member
Message 4 of 28 (118,304 Views)
03-31-2010 08:25 AM in reply to: milend
If you insert a PDF, can you still edit lines or text?
Thank you!
Active Member
Message 5 of 28 (118,302 Views)
03-31-2010 08:28 AM in reply to: milend
Thank you Terry!
I'll try it!
What about PDF2DWG converter from autodwg.com.
Can you compare these two converters?
Which one is better?
*Bill Gilliss
Message 6 of 28 (118,302 Views)
03-31-2010 08:33 AM in reply to: milend
On 3/31/2010 11:28 AM, milend wrote:
> Thank you Terry!
> I'll try it!
Try them both and let us know.
*jg
Message 7 of 28 (118,302 Views)
03-31-2010 12:47 PM in reply to: milend
No but if you convert one you generally end up with a series of dots
instead of lines since the way that most pdf's are created is as a print
driver which rasterizes the file (pdf's can be lines instead of dots if
created with the right software, but most people are cheap and use the
freeware drivers that don't do it that way.) If you think that editing a
series of dots is acceptable then you're a better man than I am, Gunga Din.
> Thank you!
Message 8 of 28 (115,541 Views)
07-26-2011 09:09 AM in reply to: milend
I've tried a couple of these.  They only work if the PDF was created by a CAD or vector graphics program.  If it is a scanned image or created by a raster based program, all you get is a raster image.
Active Member
Message 9 of 28 (115,536 Views)
07-26-2011 01:30 PM in reply to: RickW363
This is correct. However we have used a program called pdf2cad v.8 with much success. First you save the pdf file, open the pdf2cad program to convert pdf file to CAD. Then you open file as a dxf into cad and save as .dwg and you're good to go. You do have to scale the dwg up to get it back to 1:1. Somehow it loses it's scale in the conversion process.
My job requires me to draw seating layouts for churches/synogogues/colleges/funeral homes and courtrooms. However at the front end of a project, architects are reluctant to release a CAD file so we end up with a PDF. In the past we had to plot and then scale the entire drawing by hand to recreate in AutoCAD. Since we discovered pdf2cad, that is a thing of the past. We save hrs on every project and are much more accurate and efficient. All I can say is that it works for us! It's a great program!
New Member
Message 10 of 28 (100,798 Views)
03-29-2012 09:49 AM in reply to: milend
I am not a business just a teacher with a hobby, one of reprographics problem is converting PDF to DWG format. I have tried Any PDF to DWG Converter and Aide PDF to DXF Converter, they work very well, I really like Any PDF to DWG Converter.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
