• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    Active Member
    LMAN betw. A2007 and A2008
    123 Views, 6 Replies
    10-29-2007 09:52 AM
    Two users working on a dwg. One has Autocad 2007. One has Autocad 2008. Layer manager loses its saved states when moving from 2008 to 2007. Any suggestions?
    Please use plain text.
    *Dean Saadallah
    Re: LMAN betw. A2007 and A2008
    10-31-2007 05:01 AM in reply to: tsteele
    2008 moves lman states to Layer command's states, a new 'feature'.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Add-on products for LT
    http://www.pendean.com/lt
    Active Member
    10-31-2007 07:15 AM in reply to: tsteele
    These new 'features' are...um...a pain in the neck. But what's new? Know any way around this, except for moving up to 08? I noticed the change but cannot get one to work with the other.
    *Jason Rhymes
    10-31-2007 09:23 AM in reply to: tsteele
    Look at #4
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=4091678&linkID=9240618
    Active Member
    10-31-2007 11:48 AM in reply to: tsteele
    Thanks for the link. However, the installer will not allow me to execute the CCTsetup file. I think it's because I have 2007. Web says it's for '04-'06. I did instal the scriptpro file. I am by no means a script pro. Is there something I'm missing in this program that will allow me to make the conversions? If so, I think I'm too stupid to find it. I caught myself searching for the -07 CCTsetup file, but ti doesn't seem to exist.
    *Jason Rhymes
    10-31-2007 12:42 PM in reply to: tsteele
    According to the readme file. (see below) They also have it referenced in
    the 2007 help file (CONVERT TO LAYER STATES) but you're right, it doesn't
    work with 2007. The last time I used it was in acad 2005. Wonder why they
    have not updated it? This is going to cause problems for me also since I
    come across older dwgs that I used lman on.
    Supported Products
    AutoCAD® 2004 and later
    Autodesk® Architectural Desktop 2004 and later
    Autodesk Map® 2004 and later
    Autodesk® Land Desktop 2004 and later
    Autodesk® Mechanical Desktop® 2004 and later
    AutoCAD® Mechanical 2004 and later
    Active Member
    10-31-2007 01:07 PM in reply to: tsteele
    Found the files for the converter here: http://forums.augi.com/showthread.php?t=17079
    You have to Join AUGI, but it's free.
    But wait, they don't appear to work in '07. Rats!
