AutoCAD Forum
Importing files to AutoCad and editing them
1 REPLY 1
shosler
479 Views, 1 Reply
Ok, i would like to know how our old Cad guy would take PDF's from BlueBeam and put them in AutoCad.
Example: I added serveral notes to camera port detail in BlueBeam. Somehow our old Cad guy, would copy just that 1 detail and put it in model space. Its really cool because theres layers to the copied detail so you can edit/make changes in AutoCad. The importing kinda messed a few of the lines up, like the arc line caulking joints i made. AutoCad can select the caulking joints i made in BlueBeam and i can then delete them and make a new ones in AutoCad.
I figured out how to import a whole PDF document into AutoCad but the page you insert in not clickable/changeable and its the whole page.
I'm attaching what the old Cad Guy did. You can see that he imported just 1 detail and not a whole page. And its clickable/changeable.
Please help.
1 REPLY 1
pendean
in reply to: shosler
Again, in the wrong forum: let the forum admin know what your AutoCAD version is so that it can be moved to the correct forum.
PS: your file contains no PDF information, looks like you guy used a translation software to convert a PDF to a DWG file. He used a purchased or 3rd party program to do so, not an option if you only have AutoCAD.
”Boost
