AutoCAD Express Tools
Active Member
tfoley
Message 1 of 8 (30,682 Views)
I need to count blocks in a drawing
30682 Views, 7 Replies
05-05-2006 09:21 AM
Simple question I know. . . I need to list all the blocks in my drawing and how many of each there are. Can anyone help?
Distinguished Contributor
JoshNelson
Message 2 of 8 (30,680 Views)
Re: I need to count blocks in a drawing
05-05-2006 09:37 AM in reply to: tfoley
Tools -Quick Select - use the filter criteria to pick all blocks with the block name you want and then check your properties window to see how many blocks you have picked.
Josh Nelson
Active Member
tfoley
Message 3 of 8 (30,680 Views)
05-05-2006 09:43 AM in reply to: tfoley
I have 40 different block names each block has about 30 instances. so I dont want to q-select 40 times and type in the name. isn't there a way to list the names and quantities of all the blocks in the drawing at the same time?
*Jay
Message 4 of 8 (30,680 Views)
05-05-2006 10:03 AM in reply to: tfoley
BCOUNT
Active Member
tfoley
Message 5 of 8 (30,680 Views)
Josh
"BCOUNT" is the one. I just forgot about it. Thanks for your quick response though.
Active Member
tfoley
Message 6 of 8 (30,680 Views)
05-05-2006 10:04 AM in reply to: tfoley
Thanks. I knew it was there but couldn't remember the command.
*Tracy Lincoln
Message 7 of 8 (30,682 Views)
05-06-2006 04:48 AM in reply to: tfoley
Depending upon which release of AutoCAD and Express Tools you are using,
BCOUNT is a viable utility, but be careful if you have nested blocks or
xref'd blocks.
You also might want to look at EATTEXT and realize that the blocks do not
have to have attribute definitions in them in order to use this command to
gather information about the blocks, nested blocks or xref'd blocks.
AutoCAD Quick Tip - Another Super Speedy Means of Counting your Blocks!
http://lynn.blogs.com/lynn_allens_blog/2005/02/index.html
(you'll need to scroll down to read the blog post)
Tracy Lincoln - Autodesk Discussion Group Facilitator
TLConsulting - http://TLConsulting.blogspot.com/
wrote in message news:5165571@discussion.autodesk.com...
New Member
EEMay
Message 8 of 8 (25,771 Views)
10-11-2011 04:23 AM in reply to: tfoley
To make a table of all the blocks on your drawing and their quantities:
(Tools>>Attribute Extraction>>Next>>Next>> -if you want the number of all the blocks press Next--if you dont need to know all the blocks numbers then >> tick the box exclude blocks without attribute>> choose the needed blocks- >>Next>>Next>>Next>>Finish. ^_^
Good Luck
Your Friend,May
You are not logged in.
Ask the Community
