• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    Valued Contributor
    Express Menu MKLTYPE Command
    1909 Views, 3 Replies
    07-30-2002 02:27 AM
    Can anyone help me out with making linetypes with this Express menu command. I either get a straight line from my shape or dots at the vertex and that's it.
    I'm trying to make an edge of pavement linetype.
    Thanks for any help.
    Please use plain text.
    *Edgetrimmer
    Re: Express Menu MKLTYPE Command
    07-31-2002 01:21 PM in reply to: three_dogs
    I know how to use mkltype but I don't know what an
    "edge of pavement" linetype looks like.  The general procedure for a simple
    linetype (one without shapes or text) is as follows (I tend to be wordy so it
    looks like more work than it is):
    1.  Use line and/or point commands to create a
    representation of what you want your linetype to look like at a 1:1 scale.
    For example to create a linetype named DASH2DOT you would only need to draw a
    horizontal line say 1" long then use the point command to place 2 nodes to right
    of and in line with 1" line say at .10" spacing. ( ----- . .)
    2.  Start mkltype command and either select an
    existing linetype file (.lin) or create a new one when prompted.  (Highly
    recommend you use a custom file in a non-AutoCAD program path folder for
    linetypes you create rather than adding them to acad.lin.  When you upgrade
    AutoCAD, you'll be glad you did.)
    3.  Enter linetype name when prompted.
    (Avoid punctuation and special characters in the name.)
    4.  Enter a brief description; can either be a
    few words or a keyboard representation such as ----  . . ---- for a
    linetype named DASH2DOT for example.
    5.  Pick left end of first line you drew for
    your linetype when prompted for starting point and then ortho point to right of
    starting point which includes all objects you drew to represent your linetype on
    the screen.  In the above DASH2DOT example the endpoint to pick would
    be at X1.30" and Y0.00" if the 1" long line started at 0,0 and you place 2 dots
    (nodes) at .1" spacing past end of line.
    6.  Finally select all the objects which make
    up your linetype representation from the screen.  In the DASH2DOT example
    that would be the 1" long line and the 2 nodes.  Voila!  You're
    done!
    Your linetype is loaded and ready to use.  For
    linetypes which include shapes or text, the procedure is the same.  Just
    place the shape or text in line with the line and include it in the
    figuring where the endpoint will be.  You can of course keep using the
    custom linetype file for any new linetypes you create.  Their definitions
    will be appended to the existing definitions in your custom .lin file.  For
    other drawings, load the new linetype with the linetype command by browsing to
    whatever folder you decided to put your custom linetype file in.
    Good luck,
    Edgetrimmer
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Can
    New Member
    tcam123
    01-19-2012 09:15 AM in reply to: three_dogs
    How would I create a new line type that consists of a black line with a white box around it?
    New Member
    05-26-2012 02:57 AM in reply to: tcam123
    Hi @tcam123 I think you should follow @Edgetrimmerguide to get information to make black line with a white box around it.
