• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Express Tools
    New Member
    DWG to PDF save as -> filename empty
    1225 Views, 2 Replies
    08-24-2012 01:23 AM
    Hello, I'm having a weird problem, whenever I want to save my DWG to PDF I use the builtin pc3 from Autodesk. Normally when I use it, the filename of the dwg is suggested as name for the pdf. But now this is empty and when you have to save 20-30 pdfs a day this is a pain to type over the names everytime. When I use PDFcreator however, it does suggest the name correct, but then I dont have the correct paper sizes. Best regards!
    Please use plain text.
    Charles_Shade
    Re: DWG to PDF save as -> filename empty
    11-28-2012 05:02 PM in reply to: JordyMin
    Its been a while...
    But what you got in the Publish dialog
    Prompt or Specify?
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    pendean
    12-04-2012 05:24 AM in reply to: JordyMin
    save to PDF means what to the rest of us in AutoCAD: What exact command are you using my friend, and what AutoCAD version?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
