AutoCAD Express Tools
New Member
jmaier
Message 1 of 3 (4,093 Views)
Converted Drawing from MM to Inches
4093 Views, 2 Replies
10-03-2012 03:51 PM
I have a drawing that was drawn in MM, I re scaled the drawing by a scale factor of .03937, when I check the dimensions it appears that it is still off by around 5"
Anyone ever experienced this before
pendean
Message 2 of 3 (4,061 Views)
Re: Converted Drawing from MM to Inches
10-08-2012 11:27 AM in reply to: jmaier
1mm=0.03936996inch
You are close enough that 5" (1237mm)  just means the wrong MM dimension was used for the object you are measuring perhaps: what bare you measuring, and where?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
jmaier
Message 3 of 3 (4,054 Views)
10-08-2012 01:22 PM in reply to: pendean
I drew a line and re scaled the drawing, it was a PDF file convertered to a DXF and it was off by 5 ", so I just Re scaled the drawing and it came out perfect, small learning curve
John Maier
You are not logged in.
Ask the Community
